More than 24 hrs for porting
SarthakS4538
Hi team,
I have applied for a porting request in 48 from my vodafone number 0892473004. However, its been more than 24 Hours, but my sim has not yet been ported.
Please look into this regard and kindly advise if there's anything that I can do from my end to expedite the process.
Thanks & Regards,
Sarthak Sinha
48 support don't generally monitor or respond to posts here on the Community Forum.
You'll need to contact them directly yourself if you want assistance with this issue.
It might also be worth reviewing the porting FAQ in case that helps:
By the way, it's not a great idea to post personal details such as your phone number in a public forum like this where anybody can see and use it.
You might want to edit your post to remove it.
