I want to reactive my credit I bought credit and I want to top up but didn't work because I have to reactive my credit cause I didn't top up any since I got it so please I need help to active my credit I really need it
Did you buy a credit voucher and try to topup your cash credit balance with it but there was a problem?
Yes
Who/what is telling you to "reactivate" something? Women was working in shop
18 REPLIES 18
Your post doesn't make sense.
What do you mean by reactive (reactivate?) credit?
What exactly did you do/try to do?
Topup your cash credit balance?
Buy membership/add-ons?
What does your My48 page say about your current membership status, expiry date and membership allowance balances?
https://www.48months.ie/my-48
Does that page also list any next membership(s) and a start date?
What does your My History page say about recent payments/purchases?
http://www.48months.ie/my-48/my-history
You might also want to try contacting 48 support in case they can advise:
That's my number **bleep**
EDIT: removed personal info
And basically no one can call me I can't get any messages and also I can't top up
So I don't know what's the problem
You shouldn't post your number in a public forum like this.
You haven't answered the questions that I asked above.
If you do then I might be able to advise.
Otherwise you'll need to contact 48 support as I suggested.
Yes
What was the problem when you tried to topup using the voucher?
If some woman in the shop said you had to "reactivate" your credit then I have no idea what she was talking about unfortunately.
If you are having problems topping up with a voucher that you have bought then you're almost certainly going to have to discuss this with 48 support as I suggested above.
Unfortunately they won't be online again until tomorrow morning (8am I think?).
What Exactly did you do/try to do? I want my 48credit work
Sorry - I don't understand this.
