11-09-2024
04:00 PM
- last edited on
11-09-2024
04:16 PM
by
11-09-2024 03:09 PM
11-09-2024 03:10 PM
11-09-2024 04:14 PM - edited 11-09-2024 04:15 PM
Did you follow the instructions?
What happens when you try?
Any error messages?
If you can't get the porting security code by text are you sure that you have the old provider's SIM installed and working in the phone in order to receive it?
If you no longer have service with the old provider then you need to contact them as per the instructions above.
11-09-2024 03:55 PM
11-09-2024 04:17 PM
Multiple posts merged into one thread.
There's no need to post multiple times in different threads about the same issue.
