06-07-2024
06:17 PM
- last edited on
06-07-2024
06:50 PM
by
Hello how long is take a to processing my SIM card 48 and my phone number I’m a starting 48sim card today and I still wait for 1gb wifi and to top up my 48 SIM card
06-07-2024 06:50 PM - edited 06-07-2024 06:53 PM
You might want to review the New to 48 FAQs in case they help:
Did you successfully activate your SIM?
Did you successfully port your number?
Does the correct number appear on your My48 account?
Do you have a connection to the 48 network?
Did you configure your APN settings for mobile data to work?
Text "APN" to 50048 and follow the instructions to do this:
Are there any messages when you log into your My48 account?
