Problem with mobile data
StewartL7399
It seems I've only been able to use 5gb of data so something is blocking it,my son setting are wrong
StewartL7399
My data settings are wrong I meant to say
If you mean that your APN settings aren't letting you use your mobile data then text "APN" to 50048 and follow the instructions here to configure them correctly:
