Data connection not working
DanielMcI8601
Phone shows connected but data is not working. Is there an outage?
Working fine for me in Dublin.
You might want to contact 48 support about this.
See the link in my signature below or email them at support@48months.zendesk.com
Don’t have connection
What exactly do you mean by "don't have connection"?
No connection to the 48 network at all?
If so, what networks can you see when you do a manual search?
Or no calls/texts/data?
Does anything work - calls, texts, data?
When did things work ok last?
Do you have an active membership?
Did you configure your APN settings correctly?
