no network after returning from holidays android
AnnMarieM4770
Help. My roaming didnt work in spain so my friend messed around for a couple of hours and managed to fix it. Now ive no service in Ireland and changing and adding the 48 internet APN isnt working. Can someone please help me?
Does this help at all?
https://community.48.ie/t5/The-Knowledgebase/The-Roaming-Troubleshooting-Guide/ta-p/52179
If not then you'll probably have to contact 48 support.
6 REPLIES 6
This was brilliant, thank you so much! I'd never have found that myself
Glad it helped @AnnMarieM4770
MaureenK5900
I had the same issue, had no service when I returned from holidays. Nothing suggested worked for me but this did; settings > mobile data > sim applications > when abroad > network selection > manual > local home profile. My 48 appeared after a few seconds. I use an iPhone, not sure if it works for android.
Strange, the instructions here are slightly different under "Returned home?":
MaureenK5900
It is strange, but it was the only thing that worked for me when I returned to Ireland from Spain.
