how do i fit a sim card in an a5 samsung phone
mirslong
I can't fit my sim card in my A5 samsung phone
I presume you mean that it's too big so you have a mini or micro SIM but the A5 takes a nano SIM?
It may be possible to get bigger SIMs cut down to a smaller form factor but the safest way to get the correct SIM size is to order a replacement SIM - see here:
Need to swap your SIM
Thank you. That's great.
Glad it helped.
Make sure to choose "Swap my SIM" rather tha "Block my SIM" so that you can continue to use your existing SIM until you get the replacement and then activate it.
I did this recently for somebody and the activation was more or less instantaneous.
