changing phone
lbsunflowers
Hi, have new phone, not sure it will take the same SIM card. What is the process for switching my account to a different phone ... is it just a case of ordering a Trio SIM from 48? Thanks!
If you need a different sized SIM for the new phone then you can order a replacement trio SIM here:
Change my SIM
Change my SIM
