2 hours ago - last edited an hour ago by dalyer
an hour ago - last edited an hour ago
You'll need to post a bit more information than that if you want assistance from the Community Forum.
What exactly do you mean by "locked"?
Please describe clearly what issue you are encountering.
What are you trying to do, what steps are you taking to do it, what happens/goes wrong, any error messages?
When was your phone/SIM working properly last?
When did you last buy a membership plan?
Do you have an active membership plan right now?
If you get to contact 48 support about this then see the links in my signature below.
