Using samsung a5 roaming Internet not workimg
emmaaaa
Bought the Guido for roaming and calls work butwhen I turn on mobile data it doesn't work 😕
6 REPLIES 6
Check your internet settings.
If the APN field has changed from 48months.liffeytelecom.com then change it back to that, save the change and then switch airplane mode on and then off and try data again.
This tweak has worked for some but not all people who have had this data problem while roaming in the EU on a Guido membership.
Did that help at all @emmaaaa?
emmaaaa
Unfortunately not it still won't work 😕 is there anything else I can do?
emmaaaa
Is it anything to do with the network mode 2g or 3g or lte 2g (connect automatically) seting under mobile data? Thanks 🙂
You'll have to contact 48 support so.
Were 48 support able to help @emmaaaa?
