23-12-2023 08:22 PM
23-12-2023 08:28 PM - edited 23-12-2023 08:30 PM
Did it ever work?
Did you just join 48 and/or port your number from another provider?
Do you have a connection to the 48 network?
Can you make calls?
Can you send/receive texts?
Do you have an active membership?
If you need to contact 48 support about this then see the link in my signature below or email them at [email protected]
23-12-2023 08:34 PM
23-12-2023 08:47 PM
OK - given that you can make calls but cannot receive them you will probably have to contact 48 support about this for more assitance. See my previous post.
