Signal
MaryR6284
My signal is terrible
You'll need to post more info if you want assistance.
What exactly is the problem?
Can't connect to a network at all?
Calls unreliable, poor sound quality, drop etc.?
Data slow?
Was it always like this or did it work ok before?
When did you start experiencing problems?
Where are you located?
