4 hours ago - last edited 49m ago by dalyer
I am roaming in France and when I try to use my phone it says I am out of minutes and data. I just set up my account yesterday and have not used any. Anyone can help
49m ago
What does your My48 account Dashboard say about your current membership plan status, allowance balances and expiry date?
Were all services working ok before you left Ireland? Calls, texts, mobile data?
Where exactly is it saying that you're out of minutes and data?
Do you have a network connection to a local network? I.e. signal bars?
