Using data roaming in France
PatrickL1925
Hi all,
I have 14gb data for roaming, I am now in France, i would just like to know how to activate data roaming for use
You shouldn't have to activate anything - it should just work.
Do you have a connection to a local network/signal bars?
Are calls and texts working?
What are your APN settings?
However, note the following...
