Roaming
Michaels2078
Why will data not work in lanzrote
Try the links posted here
https://community.48.ie/t5/Internet/How-to-fix-no-network-service-when-roaming/m-p/56677/highlight/t...
CiarnH4537
Hello - not sure how to start a new thread. I am away currently and have used my 10GB allowance. I bought the add on 1Gb €3 which I thought I could use for roaming. I don’t seem to be able to. Is there anything else I need to do?
According to this data add-ons should work while roaming in the EU/UK is you've used up your membership roaming data allowance.
https://community.48.ie/t5/The-Knowledgebase/Roaming-Using-your-phone-abroad/ta-p/53115
If that's not what you're seeing then you'll have to contact 48 support and ask them about this. See the link in my signature below.
