Problem activating voicemail & with Refurbed.ie phone camera
EamonnF7806
I purchased a Huwaei P lite 30 phone  through MY 48   a year ago
I am very happy with the phone, working very well with just 2 problems that I cannot fix
1            I have followed all instructions and recorded my voice mail and it is there  when I play it back. However it does not click in when someone calls me and there is no message for the caller. It just rings out eventually. It is a big drawback to be without an active voicemail. How do I fix it ?
2  Usually the camera  takes good quality photos, but with the triple back camera as well as the front one  y the people /scene I am taking  are sometimes blurry/foggy. I clean the lens and it improves it a bit . Is there anything I can do to have clear focus all the time.
2  ( b)  When I open the photo in Gallery there is writing on the bottom of the picure....Huwaei etc   I have to crop the bottom of the picture but that is a nuisance.
Can anyone suggest solutions ?
Thank you.
If the voicemail setup instructions don't work for you:
then you'll have to contact 48 support for further assistance.
See the link in my signature below or email them at support@48months.zendesk.com
You should probably contact Refurbed.ie about the camera issues:
The gallery issue sounds like it could be the default watermark which can be modified or turned off as required:
Michaelc0891
Voice mail not working
You'll need to post a bit more information than that if you want assistance from the Community Forum.
What exactly isn't working?
Did you follow the instructions here:
If so, what problems arose and at what point?
Any error messages?
You need to read and follow those instructions very carefully as it's very easy to make mistakes with the numbers/number formats required.
