10-01-2025
07:09 PM
- last edited on
10-01-2025
07:14 PM
by
I have not been using my 48 sim with my Irish number for 3 months now as I moved to an Spanish number when I went to Spain. As I returned to Ireland, I renewed my 12.99 plan but still the 48 sim was showing its a unknown number. Could someone help me fix this problem.
10-01-2025 07:14 PM
Your SIM shouldn't get deactivated unless you didn't buy membership for 6+ months.
What exactly do you mean by "the 48 sim was showing its a unknown number"?
Where exactly is this happening?
Are there any issues/error messages when you log into your My48 account?
Does it display the correct phone number here?
10-01-2025 07:32 PM
10-01-2025 07:37 PM
> So when I go to the sim card manager, I put the sim card slot 1, then it shows 48 under it and then it shows unknown number
In my experience that's not unusual even when the SIM is working fine.
Does your My48 account Dashboard say that you have an active membership plan?
Can you make/receive calls, send/receive texts, use mobile data?
If not then what happens when you try?
Do you have a connection to the 48 network - i.e signal bars?
10-01-2025 08:06 PM
10-01-2025 08:26 PM - edited 10-01-2025 08:28 PM
Ok, I don't understand what's going on so.
You might want to try a replacement SIM.
What happens if you try to do a manual search for networks?
What about if you follow the instructions in this article under the heading "Returned Home?"?
You should probably contact 48 support for further assistance.
BTW this is what my phone shows for my SIM even though it's working fine...
