No signal
MitraA3561
Good morning
I have no signal at all for few days
You mean no connection to the 48 network/no signal bars?
When was it working ok last?
Did anything change since then?
E.g. phone software update, settings changes, factory reset/restore, returned from roaming abroad, etc.?
If you do a manual search for networks can you see and connect to 48?
