No signal after holiday
Nikitag9149
I have no signal after arriving home from holiday?
Try the instructions here under "Returned Home?"
If that doesn't work then you'll probably need to contact 48 support.
Thank you so much it worked straight away!
Great, glad it helped and you got sorted!
