No connection - can't make calls for 2 days
Carmelb0385
Your post was blank @Carmelb0385 and the subject line doesn't provide a lot of info.
If you want assistance from the Community Forum then you need to describe your issue in detail.
When were things working ok last?
Did anything change on the phone in the meantime?
E.g. settings changes, software update, factory reset, changing phones, returned from roaming abroad, etc.?
Do you have a connection to the 48 network?
Does it make any difference if you reseat the SIM?
You say that you can't make calls but can you receive calls, send/receive texts, use mobile data?
