New phone - mobile data & NI roaming not working
MarieS7771
I changed my fone to redmi...have huge problems my fone working in northern Ireland also revolut won't recognise my data outside my home WiFi..any suggestions I have reloaded revolut app loads of times..this never happened before
You probably just need to configure your APN settings on the new phone:
On Android you can text "APN" to 50048 and follow the instructions here to do this:
