Network very slow
MianA5033
6 REPLIES 6
Are you sure that your APN settings are configured correctly?
MianA5033
I am not happy with 48 my net work is very slow
MianA5033
ViktorI3819
In Drumcondra, Dublin 9 the network speed is very slow around download 4 - 6 mbps
Upload is better at around 15 mbps
Same questions as before...
You'll need to post a bit more info than that if you want assistance from the Community Forum.
How slow?
What speeds using something like Speedtest?
Are your APN settings configured correctly?
Was it ever working better?
Where are you located?
Do you know others on 48 to check how they get on?
If you need to contact 48 support then see the link in my signature below or email them at [email protected]
