3 hours ago - last edited 3 hours ago by dalyer
Your post was blank @AlanM0032 and the subject line seems truncated and doesn't clearly explain your issue or question.
If you want assistance from the Community Forum then you need to clearly describe your issue or question
What exactly are you trying to do, what steps are you taking to do it, what happens/goes wrong, any error messages, etc.?
Are you just trying to join 48 or has it been working for you before this?
If it was working before then what changed in the meantime?
Phone software update, settings changes, factory reset, new phone handset, returned from roaming abroad, etc.?
