My SIM card is not working what should I do?
KoffiG1595
My sim card is not working. What should I do. Thank you
You'll need to post a bit more information than that if you want assistance from the Community Forum.
When was it working ok last?
Did anything change on the phone in the meantime?
Software update, settings changes, factory reset, new phone, returned from roaming abroad, etc.?
What happens when the phone is installed in the phone?
Any error messages?
Can you get a connection to the 48 network - i.e. signal bars?
Any other relevant info?
