19-07-2026 05:03 PM
19-07-2026 07:02 PM - edited 19-07-2026 07:03 PM
What do you mean by WiFi?
Do you actually mean mobile data?
WiFi is a connection to a wireless local area network and has nothing to do wth 48.
Mobile data is a 48 issue and nothing to do with WiFi.
Is anything working?
Incoming/outgoing calls?
Incoming/outgoing texts?
Mobile data?
