Roaming doesn't work in spain
KacperP0086
Can someone help , my roaming doesn't work in spain .
My phone model is Redmi Note 10 5G.
Does anything work for you?
Incoming/outgoing calls?
Incoming/outgoing texts?
Mobile data?
