Look to block my phone full network
MickC5746
Looking to block my number as my son uses the phone and I need to be able to shut the phone off and on from my phone. How can I do this?
What exactly do you mean by "block my phone full network", "block my number", and "shut the phone off and on from my phone"?
What exactly are you trying to do here?
Exactly what services do you want him to be able and unable to use?
Restricting access to specific services is most likely something that can only be done using the phone's security, accessibility, or other settings or maybe using a third party app and not something that 48 can enforce.
If you're using an iPhone then maybe something like Guided Access is what you need?
If you use Android then maybe something like App Pinning is what you need?
