Iphone 5c not connecting in spain
ab3rgy
Hi. My phone has no signal in Spain. What are the steps to switch on roaming please?
6 REPLIES 6
Almost certainly the usual iPhone roaming problem due to the stupid way that Apple do things.
See here:
https://community.48months.ie/t5/Internet/Can-t-text-using-roaming-in-spain/m-p/45016#M2306
Thank you for reply. Will let you know if it works
Did that help at all @ab3rgy?
Hi. Still no joy I'm afraid. I have EU roaming calls and texts added before I travelled but can get no connection whatsoever. Is there a big difference in the iPhone settings?Thanks for all your help.
It's an iPhone problem due to the stupid way that Apple do things.
You have to use the tip here and may have to try many times before it works.
You will need to be persistent.
Toggling airplane mode on and then off again and trying the reconfiguration quickly may help to "catch" the local network allowing the reconfiguration to work.
http://community.48months.ie/t5/Most-Popular-Questions/iPhone-abroad-issue/td-p/36862
Any update @ab3rgy?
Did you keep trying and get it to work?
