How do you open slot and insert SIM card
GeoffreyM4974
Your post was blank @GeoffreyM4974 and the subject line doesn't make completely clear what your question or issue is.
If you are asking how you open the SIM tray/slot on your phone and install the SIM then you need to check the instruction manual for your specific make and model of phone.
If your question is about something else then please clarify what it is.
