Honor Play Network Issues
chawke
Right now I am in Spain, when I got off the plane I noticed that I couldn't get service, it would connect to a network and then immediately disconnect. I don't know if it is a problem with my phone (Honor Play) or if it is a problem with 48/my sim. Does anybody know a way I can fix this?
What membership do you have?
EU roaming only works on Guido.
If you have Guido then do a manual search for local networks and see if you can connect to any.
If you can't you'll probably have to contact 48 support.
Did that help at all @chawke?
