Dropping calls
mildred8251
Regular
Is anyone else having problems with dropping calls,very low coverage I noticed all day today and yesterday. It's doing my head in
Was everything working fine for you before?
If so when did things start playing up?
Was there any change to your phone before this happeend - e.g. software update etc.?
Are both incoming and outgoing calls affected?
Do incoming/outgoing texts and internet work OK?
You should contact 48 support and ask them about this as they may be better placed to investigate/comment:
Did that help at all @mildred8251?
mildred8251
Regular
Seemingly it's the sim. New one ordered. Thanks
OK - thanks for the update @mildred8251.
mildred8251
Regular
