07-08-2026 01:50 PM
07-08-2026 02:20 PM - edited 07-08-2026 02:24 PM
What does "my done went to the im" and "he has arrived back from the im" mean?
What exactly do you mean by "he has zero credit"?
What does his My48 dashboard say about his current membership plan status and expiry date?
Incoming/outgoing calls?
Incoming/outgoing texts?
Mobile data?
An active membership plan is needed in order to be able to use outgoing services.
If he went abroad and is back in Ireland now and has problems with service then maybe look at this key post - in particular the section titled "Returned Home?":
If you're not clear on how 48 works then you should probably read the New To 48 FAQs which explain how things work since it's a bit different to some other SIM only pay as you go providers.
