Data/calls/texts not working - "not registered on network"
Terrym4333
My data calls and texts not working , when I try to make a call it says not registered on network, i feel lik 48 has cut me off,any one else have this , or know what I should do?
Terrym4333
Was it working before or are you just joining 48?
If it was working before and stopped then when did this happen?
Did anything change? Settings changes, software update, factory reset, new phone etc.?
Do you have a connection to the 48 network?
