Contacts not registered - can't call them
MarieC3510
My 48 will not allow me to make calls to any of my contacts. Contacts are not registered. It was working this morning.
I have turned the phone off and on. Also put it on airplane mode and turned it on again. Neither of the above worked.
What do you mean by "contacts are not registered"?
Did anything change on the phone between when things were working ok and when this problem arose?
E.g. software update, settings changes, factory reset/restore, new handset, returned from roaming abroad, etc.?
Why error messages?
Does it make any difference if you dial the contact number manually or call a non contact number?
Can you receive calls?
Can you send/receive texts?
Looking at your posting history you seem to have had problems with contacts before but never responded to suggestions/advice that I posted.
Maybe there's some problem with your phone?
