Can't receive calls other than Whatsapp while in UK
AnnG9301
What exactly is/isn't working in terms of the phone connection (and not WiFi for example)?
Incoming/outgoing calls/texts?
Mobile data?
On the general issue of roaming, the usual generic advice applies...
