Roaming
ClaireR7890
My data doesn’t work while I’m abroad but my WiFi does
What country are you in?
What exactly is/isn't working apart from mobile data not working?
Incoming/outgoing calls/texts?
On the general issue of roaming, the usual generic advice applies...
