30-10-2017 02:10 PM
30-10-2017 02:37 PM
See here for instructions on how to set up your 48 voicemail.
Read and follow the instructions carefully as any mistake and it may not work.
http://community.48months.ie/t5/Most-Popular-Questions/How-do-I-use-my-Voicemail/td-p/44
30-10-2017 05:37 PM
02-11-2017 11:30 AM
02-11-2017 12:49 PM
If it did not work then chances are you did not follow the instructions exactly as laid out.
Those instructions definitely work for enabling voicemail.
If you can't get it working then you may need to contact 48 support for more assistance.
02-11-2017 03:40 PM
06-11-2017 10:44 PM
