APN settings
CatherineW3812
I am trying to update my settings. I am using Set B. When I try and save it, it is looking for 3 digit no. for MCC and 2 digit no. for MNC, but these have no numbers in Internet column, It should be Not set. If I can't save it my phone won't update.
6 REPLIES 6
What do you mean by "Set B"?
What make and model of phone?
Did you follow these instructions?
According to those instructions the settings should be:
  • MCC = 272
  • MNC = 11
Hi It gave me 2 options A or B. My phone is a Samsung 10 and I have to use option B
What gave you option A or B?
You're not really explaining things clearly.
See the link that I posted above which explains how to configure the APN settings for use on 48.
If the instructions there don't work then explain clearly what the issue is, what doesn't work, any error messages etc.
If you need to contact 48 support then see the link in my signature below or email them at [email protected]
YingL8591
Hi Have you figured out what to do? I have the same problem.
See here:
JohnOC3997
The following APN settings worked for me and my daughter using Android roaming Italy 2023 / Menorca 2024 / Portugal 2025 / UK 2024 & 2025.
Make sure that you have enabled data roaming (search settings for your phone) also adjust setting in 48 Sim App - When Abroad - Network Selection - Manual - International Roaming Profile.
In the APN type, make sure to use a comma (not a full stop) between words and also use caps for Liffeytelecom
Name - 48 Internet
APN - 48months.Liffeytelecom.com
Proxy - Not set
Port - Not set
Username - user
Password - Not set
Server - Not set
MMSC - Not Set
MMS proxy - Not set
MMS port - Not set
MCC - 206
MNC - 01
Authentication type - None
APN type - default,mms,supl,hipri,fota,cbs,mcx,xcap
APN protocol - IPv4/IPv6
APN roaming protocol - IPv4/IPv6
APN enable/disable - APN enabled
Bearer - Unspecified
MVNO type - None
MVNO value - Not set
After saving, switch on airplane mode and then switch off after 30 seconds and the internet signal should show, may take a minute.
If it does not save or go blank, you have not imputed correctly, I have made mistakes and had to recheck everything to get to work, but with perseverance it worked in the end.
