whats a guido and a duke?
Is a guido or duke free calls and text for the month ? I'm confused
The membership deals are described here:
http://48months.ie/deal
Guido = all texts + 100 mobile mins + 20 landline mins + 1GB data
Duke = all texts + 500 mobile mins + 20 landline mins + 1GB data
You might want to look at the Mitch and Don memberships if you want unlimited texts and calls.
Note that fair usage limits apply so "all texts" means a maximum of 5000 texts and "all [mobile] calls" means a maximum of 3000 mins:
