unable to use membership
I renewed by membership over 4 hours ago. When will I be able to make calls and use my internet???
That means that the new Don membership will kick in when your current one has expired tomorrow at midnight.
Membership always runs its monthly course and buying a new one doesn't prematurely terminate a current one. It stacks instead.
You get the benefit of the new membership allowances when that membership kicks in.
Does that clarify things for you?
Hi ardit2013
What date did/will your membership expire on?
Can you check your online account & post back please...
Membership due to expire tomorrow but received a text from 48 today saying my internet data was almost reached so brought another €20 Don
Payed membership but no service and no bars. They told me to try and put SIM card in other phone I did and nothing.
Hi ruck10
So you've aready logged a Support ticket already... & one of the care crew told you to check the Sim card?
Was the Sim working until you renewed Membership?
Did it just spontaneously stop functioning?
Is your APN Correct/in Place?
I gather that your Membership is currently Active... can you post the status here (Start/Expiry) just to double check...
Did you have Data Roaming enabled when trying to get signal? (Required)
