tethering
dawn7737
Hi there can anyone tell me where I find the password for tethering . The device im trying to connet to is looking for a password and I cant find one no where any help would be apreacited
You seem to be on Android.
This guide may be relevant:
http://www.wikihow.com/Tether-With-Android
Note that a password can (and normally should) be set on the device providing the tethered data service.
In this case I presume that you're using your phone with your 48 SIM as the data connection in which casee the password should be configured there?
dawn7737
Thanks x
