sim card activation
I've registered my sim and it shows network but can't receive calls or texts yet.
MartinSC
Hi Martin,
this seems to be a technical issue with your account.
Raise a ticket with a member of the technical staff using the link in my signature below.
MartinSC
Did you buy membership? I thought you needed to in order to be able to receive calls or texts? Maybe I'm wrong...
Hi,
Did you port your number over?
If you did not they you will have a new number so maybe you are trying to call your 48 phone with your old number. If you want to port your old number over  click here.
If the above does not apply then you will need to open a support ticket using the link below.
