settings interne 4 nokia lumia 920
pixie369
Hi can anybody help me .I just put my sim card back in after using it in my husbands phone.But says I need new settings or something .My phone is not listed in list of phones.Its a Nokia Lumia 920 .Be grateful if anyone knows? Thanks
Whenever the SIM is (re)inserted into a phone you get that message but it's meaningless - it says that it could not send the settings to your phone but it doesn't actually try to and it doesn't necessarily mean that your settings are wrong.
If the phone was used on 48 before, the APN/internet settings were correct so that internet access and MMS worked and nothing has changed on the phone then there should be no need to reconfigure anything.
Before changing anything check if your settings are OK or just try internet access over the carrier data connection (not wifi) and if it works then you don't need to do anything.
If you do need to (re)configure the settings then see here:
Internet Settings
pixie369
Thankyou so much Dalyer😊!!
So is internet access over the carrier data connection (not wifi) working OK for you?
That text on (re)inserting the SIM and rebooting is annoying and confusing.
I wish that they'd eliminate it.
