nokia lumia 520 mms
Hi:
I can't get mms to work on my Nokia Lumia 520. I've tried other generic Nokia settings but it wont work. Internet working fine. Ive been a member for 6 months.
Just follow these instructions and it will work:
You can configure a single APN that works for both internet and MMS if you use these instructions.
Remember that you also need cash credit to cover the cost of sending MMS messages as they are not included in any membership or add-on bundled allowances.
They cost 30c each.
A little note about picture messaging
