setting up sim fail
hi i just set up  a sim and its been one hour and i still havent gotten a registitration verification email. second time this has happened when i tried to register a sim and the other one ended up blocked because nobody replied to my queries! Sim registration code is: FPF9SV
Are you sure that you entered the correct email address?
Did you check your junk mail/spam folder?
If all else fails then you may need to contact support:
