replacement sim
gen360
im going to order a replacement sim and i know that your old sim gets blocked right?
Can you receieve message even though your sim is blocked, and if not can you receive them once you have gotten your new sim? will they be there when you activate your new sim?
Once the SIM is blocked it ceases to work for all services so you won't get any texts etc.
If you want to keep using your current SIM while waiting on a replacement then order a free SIM here:
http://48months.ie/free-sim
and when you get it DON'T register/activate it but log a support request with 48 asking them to activate the new free SIM on your existing account/number.
