problems with changing number
I want to keep my old number , think I may have pressed wrong thing for pay as U go or bill pay , it says there is a problem and I can change it but wen I try to go to link to change it , its says transfer in progress and won't let me do anythin
If you can't correct things through the website/form then you will need to contact 48 support for assistance:
