possible to reactivate old 48 sim
yanisirl
I was with 48 and moved to another provider as they gave me 3 months free. I would now like to move back how do I re activate my 48 sim and move my number back to 48? My wife also needs to do the same. I tried putting in my sim activation code and then the 19 digit number but it wouldn't accept it.
Thanks in advance
Yanis
You might need new SIMs but contact 48 support directly first here:
to see if they can reactivate the old ones.
