30-10-2026 10:30 AM
30-10-2026 11:24 AM - edited 30-10-2026 11:25 AM
If he has used up his EU/UK roaming mobile data allowance then he can buy a mobile data add-on to continue using roaming mobile data for the rest of the membership plan month.
See here:
Can I buy extra Data for EU/UK roaming?
Yes! If you've used your EU/UK data roaming allowance or simply just want more, then the 1GB data add-on can be used in Ireland and in the EU/UK when you’re on a plan that has roaming included. To purchase your add on, simply Log in to your My48 >> Flexi Data >> Add ons, or just click here.
If you/he need to contact 48 support about this then see the links in my signature below.
By the way, it's not really a good idea to post personal details such as one's phone number in a public forum like this where anyone can see and use it.
You might want to edit your post to remove it.
